product_Banner
EM231 PID temperature module(231-7TF36)
EM231:8*J/K thermocouple inputs, isolated 16-bit precision, with intelligent PID
Order No.:CTS7 231-7TF36
Specification:
Product Description
Product nameSpecification parameterOrder number
PID moduleEM231:8*J/K thermocouple inputs, isolated 16-bit precision, with intelligent PIDCTS7 231-7TF36
Technical Spec
Product modelEM231 Thermocouple PID module
Order numberCTS7 231-7TF36
Physical characteristics
Dimension([WxHxD)(mm)71x80x62 mm
Power dissipation1.8W
Power loss
 +5V DC consumption current54 mA
L+39 mA
L+ Coil voltage range20.4~28.8V DC
LED light indicatorThe 24V DC power supply is normal. ON= no error,OFF= no 24V DC power supply, SF: ON= The module is faulty, blinking = the input signal is incorrect,OFF= no error
Analog input characteristics
Input typeSuspension type thermocouple
Input rangeJ/K type
Input points8
IsolateField and logic500V AC
Field to 24V DC500V AC
24V to logic500V AC
Common mode input range (input channel to input channel)120V AC
Common-mode rejection>120dB@120V AC
Input resolution
Temperature and voltage0.1℃/0.1℉
15 plus sign bits
Measurement principleSigma-Delta
Module update time(All channels)825ms
Length of wire to sensorMax. 100 m
Conductor loop resistanceMax.100Ω
Noise suppression85dB@ 50Hz/60Hz/400Hz
Data word formatVoltage:-27648~+27648
Input impedance>1MΩ
Maximum input voltage30V DC
Resolution15 bits+sign bit
Input filter attenuation-3dB@ 21kHz
Basic error0.1% FS(Voltage)
Repeatability0.05% FS
Cold contact error±1.5℃
Diagnostic programLED:EXTF,SF
PID characteristic
PID algorithmPID+FUZZY argument auto-tuning
Sampling time1s
Output minimum pulse width10ms
PID typeP、PI、PD、PID
PID output typeAnalog or PWM
PID output polarityBipolar or unipolar
Installation
Wiring Diagram:
Size Diagram:
Return
