COTRUST New Product CTMC Series Release: 60 I/O H228IL
2020.03.16
1. Dimensions(W×H×D):200*116*69.5mm
2. Communication port
    2*RS485 port,PORT0:PPI/FPORT,standard RS485;
    PORT1:PPI/FPORT,standard RS485;
    1*EtherNET port(support for adaptive cross-connect)
    It can be equipped with one BD expansion board, which supports RS485, CAN and analog expansion board;
3. Support Socket free port communication, 4 Socket connections, 2 UDP, 2 TCP
4. Support 6*200KHz high speed pulse output (leakage)
    Support 6*200KHz single phase high speed counter
    Support 6*200KHz AB phase high speed counter
5. Support single-axis motion control function, and support multi-axis linear/circular interpolation function
6. Large memory: 72KB+24KB+24KB program memory /64KB data memory
7. 60 digital I/O: 36DI/24DO,
8. Super system expansion:
    Analog IO up to 32AI/32AQ, up to 194AI/194AQ after CANopen expansion;
    Digital IO is up to 128DI/128DO, up to 640DI/640DO after CANopen expansion.
9. Battery card low power alarm: less than 2V, alarm bit SM195.0
10. 24V power alarm:less than 15V, alarm SM195.1
11. Data permanent storage when power-down
12. Support online firmware upgrade
CTMC series CPU M228IL industry application:
Lithium equipment,3C,Textile machinery,Packaging equipment,Machine tool,Glasses industry, Wood machinery, Screw-cap machine,Smudge machine, Glass edging machine, Glass cutting machine, Capacitor assembly line, Winding machine, LED assembly line, Woodworking side hole machine, etc
CTMC series CPU M228IL order data
Series
CTMC series
Model No.
CPU M228IL
72KB+24KB+24KB program memory /64KB data memory,24VDC power supply,36DI/24DO leakage transistor out,0.5A,2*PPI/FPORT,1* Ethernet port,6*200KHz output(Pulse/Dir),6*200KHz high speed counter,data permanent storage when power-down,support analog expansion board,CAN expansion board and RS485 expansion board,support online firmware upgrade,support uni axial motion control, support multi-axis linear/circular interpolation function.
CTMC 218-3AI35-0X60
