H32-01 high performance CPU skilled in motion control
2019.12.17
H32-01 CPU features:
1.Compact and practical, save installation space
 Dimensions(W×H×D):34*115*101.6mm
2. Support for axis control instructions based on PLCopen
A. Support uni axial motion control
B. Support interpolation (line and arc)
C.Support electronic CAM and electronic gear
Axis configuration includes: pulse axis /EtherCAT axis/virtual axis/EtherCAT slave module axis
3. H32 integration 5 communication ports:
Bus communication ports
Provides module interface
1*USB port
Update firmware, program, data store
1*PPI/Free port
Provide serial communication
1*CAN port
Connect to CANopen slave device
1*EtherCAT port
Connect to EtherCAT slave device,support up to 8 EtherCAT slave devic
1*EtherNET port
Support remote programming,Socket communication,download/upload  program and data exchange
4. H32 multi-CPU networking function:
A、Support 32 ModBus _TCP/IP networking connections;
B、Support 8 UDP_PPI networking connections
5. H32 Large memory:
256KB+64KB program memory,1MB data memory,32KB data memory when power down
6. H32 fast operation speed:
The processing time of bit instruction is 0.086 s/step; Floating-point instruction processing time 1.4 s/step
7. H32 data permanent
8. H32-01 is good at motion control and can be widely used in OEM field
3C.Lithium
equipment
Printing and packaging equipment
Food
equipment
Textile machinery
logistics
Pallet equipment
Machine tool
Lifting equipment
Building automation
Pharmaceutical equipment
H32-01 CPU order data
Model No.
Series
H32-01
CTH-300
CTH3-CPU,256KB+64KB PM,1MB DM,32KB DM when power down,1*PPI/Free port,1*EtherNET port.1*USB port,1*CAN port,1*EtherCAT port.Support uni axial motion control.Support interpolation (line and arc),Support electronic CAM and electronic gear.The maximum number of racks is 1.
CTH3 H32-000S1
