COTRUST MagicWorks Smart Software
2016.08.17
MagicWorks PLC Programming Software
MagicWorks PLC programming software apply to CO-TRUST PLC full range of products, including CTSC-100、CTSC-200、CTH200、CTH300.
Functions:
Features:
* Strictly abide by the IEC61131-3 international standards
* Programming in both English and Chinese
* STL Ladder LAD, instruction list STL
* Tree Project Management Structure
* Real-time online monitoring, Online debugging function, online help function
* Refinement of function blocks, organization blocks and library functions
* Differentiated GPRS remote programming and Ethernet programming capabilities
* Convenient CANopen function blocks
MagicWorks HMI Configuration Software
Features:
* Rich 3D effect true color picture gallery, supports many kinds of picture form import
* Support in both English and Chinese
* Data storage records, data is not lost when power supply drop
* Recipe edit function: 100 recipes can be configured, up to 500 elements per recipe
* Rich animation capabilities,
* Powerful scripting functionality (JavaScript language)
MagicWorks SCADA Configuration Software
MagicWorks SCADA is a new function block of MagicWorks HMI configuration software,which achieve to the automation equipment or process monitoring, control and management through the computer signal.
MagicWorks TUNER Servo Debugging Software
Features:
* Open interface, supports OPC standard
* Rich function module, report form function
* Powerful real-time database
* Powerful help system, easy to use
* Parameter configuration wizard function, more structured, more easily complete a variety of parameter settings
* Real-time monitoring servo status, debugging convenience, fast fault analysis
* Can upload, download servo parameters, easy to conservation, it can make the servo running effect of multiple device keep consistently
