E Series Servo Drive With Debugger Launch
2015.04.18
COTRUST Servo drive with debugger launch,you can place order to us now! E series drive products upgrade performance,standard configure keyboard.At the same time, the encoder feedback output interface is changed from single ended drain output to 5V differential output.
Order Data:
CTSD E10-B2012-M110 | E10 series 200W servo drive(With CANopen function and debugger),adaptation Mseries motor |
CTSD E10-B4012-M110 | E10 series 400W servo drive(With CANopen function and debugger),adaptation M series motor |
CTSD E10-B7512-M110 | E10 series 750W servo drive(With CANopen function and debugger),adaptation M series motor |
CTSD E10-B1022-M110 | E10 series 1.0KW small inertia servo drive(With CANopen function and debugger),adaptation M series motor |
CTSD E10-B1022-M111 | E10 series 1.0KW middle inertia servo drive(With CANopen function and debugger),adaptation M series motor |
CTSD E10-B1522-M110 | E10 series 1.5KW small inertia servo drive(With CANopen function and debugger),adaptation M series motor |
CTSD E10-B1522-M111 | E10 series 1.0KW middle inertia servo drive(With CANopen function and debugger),adaptation M series motor |
