product_Banner
EM131-7ND Temperature module(131-7ND10)
2 NTC/PT100 and 2 Voltage/Current, 16BIT,Isolation,Integrating CPU processor.filter technique
Order No.:CTS7 131-7ND10
Specification:2 NTC/PT100 and 2 Voltage/Current, 16BIT,Isolation
Product Description
Order data
CTSC-100 EM131 Combination Input Module,2 NTC/PT100 and 2 Voltage/Current, Isolation
CTS7 131-7ND10
Technical Spec
Performance Parameters
Order Number
 CTS7 131-7ND10
Power loss
 0.8W
Power Consumption
    From +5V
0.12mA
    From L+
60mA
    L +voltage range
20.4~28.8V DC
 LED Indicator
24V DC: ON=power supply good, OFF=no supply power SF: ON=Module Failure, BLINK Input Signal Error, OFF=no fault
 Input type
Module reference ground RTD
 Input range
RTD type(select one):
Pt-100Ω ( α=3850PPm,3920PPm,3850.55PPm,3916PPm 3902PPm)
NTC(R25=10K B=3950, R25=10K B=3435)
 Voltage input range
±5V, ±10V, 0~5V, 0~10V
 Current input range
0~20mA
 Number of input
4 points totol,l2 points of PT100/NTC and 2 points of voltage/current
 Isolation
   Field to logic
500V AC
   Field to 24V DC
500V AC
   24VDC to logic
500V AC
Common mode input range (input channel to input channel)
Common mode rejection
>120dB@120V AC
Input  resolution
  Temperature
0.1℃/0.1℉
  Voltage
15bits plus sign
Measuring principle
Module update time: All channel
425ms
Wire length to sensor
100m(maximum)
Wire loop resistance
20Ω
Suppression of interference
85db@50Hz/60Hz/400Hz
Data word format
Voltage :-32000~+32000
Input inpedance
>10MΩ
Maximum input voltage
30VDC
Input filter attenuation
-3db@21KHz
Basic error
0.05%Fs(Resistance)
Repeatability
0.1%Fs
Installation
Size Diagram
Wiring Diagram
Return
