COTRUST CTH200 (V5) upgrade, perfect support S7 protocol
2020.05.31
CTH200 series V5 platform CPU -- High-performance (X),
The function is upgraded again, the value-added model includes:
CPU H224X (V5)
CPU H226XM (V5)
CPU H226XL (V5)
New features:
01. Ethernet support Siemens S7 protocol slave station function
Siemens PLC, Siemens panel and the upper computer software supporting S7 protocol are used as the master station, COTRUST CTH200 series V5 platform high performance PLC are used as the slave station, which supports S7 protocol function and supports up to 8 slave stations.
02. Support CANFree and CAN hardware configuration
CAN hardware configuration diagram:
03. Support the new version of V2 programming card
Before upgraded: CTS7-291-PC001 old version of the programming card, in common use for COTRUST PLC.
After upgraded: CST7-291-PC002 new version of V2 programming card, 4M large memory can support more functional program download
04.Support higher speed pulse output function
High performance CPU H224X(V5) : support 2*100KHz high speed pulse output
High performance CPU H226XL(V5) : support 2*100KHz high speed pulse output
High performance CPU H226XM(V5): supports 3*100KHz high speed pulse output
05.Support Ethernet port upgrade firmware function
Before upgraded: serial port upgrade firmware
After upgraded: Ethernet port upgrade firmware
06.Support socket function, widely used
CTH200 V5 high performance CPU order data
Products data
CTH200 V5 series CPU
CPU H224X V5 version
16KB program memory,108KB data memory,24VDC power supply,14DI/10DQ transistor output,0.5A ,1 PPI port,1 FPORT,1 Ethernet port,2*50KHZ motion control output(Pulse/Dir or PTO/PWM).Data permanent stored.Support Analog and CAN extension boards.
CTH2 214-1AX35-0X24
16KB program memory,108KB data memory,220VAC power supply,14DI/10DQ relay output,2A,1 PPI port,1 FPORT,1 Ethernet port.Data permanent stored.Support Analog and CAN expansion boards.
CTH2 214-1BX35-0X24
CPU H226XM V5 version
72KB program memory,110KB data memory,24VDC power supply,24DI/16DQ transistor output,0.5A ,2 PPI/FPORT port,1 Ethernet port,2*50KHZ motion control output.Data permanent stored.Support Analog,CAN and RS485 expansion boards.
CTH2 216-1AX35-0X24
72KB program memory,110KB data memory,220VAC power supply,24DI/16DQ relay output,2A,2 PPI/FPORT port,1 Ethernet port.Data permanent stored.Support Analog,CAN and RS485 expansion boards.
CTH2 216-1BX35-0X24
CPU H226XL V5 version
72KB program memory,110KB data memory,24VDC power supply,24DI/16DQ transistor output,0.5A ,2 PPI port/FPORT,1 Ethernet port,2*50KHZ motion control output(Pulse/Dir or PTO/PWM).Data permanent stored.Support Analog,CAN and RS485 expansion boards.
CTH2 216-2AX35-0X40
72KB program memory,110KB data memory,220VAC power supply,24DI/16DQ relay output,2A,2 PPI port/ FPORT,1 Ethernet port.Data permanent stored.Support Analog,CAN and RS485 expansion boards.
CTH2 216-2BX35-0X40
The upgraded version CTH200 high-performance V5 series CPU is available now!
Welcome to place order!
