Multiple Framework,Extended Over a Long Distance——EtherCAT Slave Module
2017.07.19
EtherCAT slave module:ECT-00
Order No:CTH3 ECT-00S1
EtherCAT slave module has to be used and incorporated with CTH300 series CPU.It is an important part of CTH300 series PLC system.Provide a guarantee for multiple framework and extended over a long distance.
EtherCAT slave module specification
1. Up to 128 EtherCAT slave module can be connect to CTH3-C series CPU.Up to 64 EtherCAT slave module can be connect to H36.
2. EtherCAT bus communication rate 100Mbps,the maximum communication distance up to 100m between two slave module. The topological structure is ring structure.
3. Each EtherCAT slave module allow to extend 8 I/O module(digital module,analog module,temperature module,HSC,HSP module.but CAN module is not include).
4. Support third-party EtherCAT master station,such as Omron,Beckhoff.etc.
Making standard Ethernet cable
Recommend to use Shielded Twisted Pair,24AWG
Refer to the following diagram
Installation
Please use PWR-02 power module,special design for CTH300 series CPU and ECT extend module.
EtherCAT slave module system infrastructure
